Throttle Body Sensor
Minot, ND
2020 AWD Palisade Limited
My throttle body sensor went out within the first 3 days or ~ 500 miles.
Apparently the throttle body sensor going out will disable Blind Spot Detection, Anti-lock brakes, all of your cameras, enable your check engine light, and disable your digital display - you have no idea how fast you are actually going you are driving blind!
I also have the wind noise issue - but I wanted to see if anyone else had Throttle Body issues right away.
flipray
Tampa, FL, USA
in the market
Throttle Body Sensor? Care to elaborate what part you're actually talking about? When you say Throttle Body, the first thing I think off a part of the intake manifold of the engine...
Los Angeles, CA, USA
That sounds a lot more like a bad ground or some other odd electrical gremlin that maybe also took out your throttle body sensor. There's no reasonable explanation as to how a failing throttle body sensor would cause those unrelated issues.
