replacing 2020 Palisade self leveling rear shocks
Stratham, NH
I have the clunking/rough ride issues associated with self leveling rear shock problems described by many Palisade owners on internet forums (my 2020 Palisade has 70k miles). I'm aware of the TSB 22-SS-001H issued a couple years ago by Hyundai recommending that the upper insulator be replaced on both sides to solve the problem. I believe that bulletin was subsequently pulled as the insulators are not the problem, the shocks are. My question is; Does Hyundai now manufacture better replacement self leveling shocks for 2020 and newer Palisades? I ask because I've seen several posts on the internet by owners having replaced their self leveling shocks two and three times under warrantee, If Hyundai hasn't improved the replacement shocks, what's the solution? Can I replace the self leveling shocks with standard Telluride or Palisade shocks and springs (I don't tow anything) or is there another solution? (I'm post warrantee so can use aftermarket parts if that's a better solution). TIA for the info
